My 2005 Nissan Titan is not one to start at all I replaced the starter cuz the starter was bad so it has a brand new starter has a brand new battery and still when you turn the key nothing happens no clicking no nothing but all the gauges and everything work is that a relay or ignition switch?
Did you ever get this fixed? If so, what was it? Is Your’s a console shift? Is so, there’s a small round cap on the left side of the console, next to the shift lever. Pop it off and gently slide a screw driver or tool that fits the hole until it stops. Then try to start the truck. It’s an override switch that’s operated off the brake switch. it’s powered off the brake pedal switch allowing the shifter to move and truck to start. Let us know if you got it fixed.
