1 - 2 of 2 Posts
Ive been searching for hours now and i cant find the info i need. I just installed a flip out dvd player, everything works but I have no sound. I hooked up what wires I thought would need to be hooked up but obviously not. I have a 04 le with the rockford system, Im thinking I need to hook up the factory amp somehow. but im so confused after looking at all the info. please help.
Turn up the volume...j/k. Did you hardwire it into your truck or use a harness? Double check your install, wiring schematics can be found here... http://www.clubtitan.org/forums/showthread.php?t=28399
Maybe someone that modified th RF system will chime in for you. GL
1 - 2 of 2 Posts
