Hi all,
recently I bought a 02/2006 Titan from the States and brought it to Kuwait. Unfortunatly, someone placed Deisel in the engine and when I received the car, the engine was totally bad. anyway, I decided to open it and redo it.
After facing several issues, I ended up with the following problem, and I really appreciate the help in advnace ...
I bought:
12010-7S000 Piston
12033-7S003 Ring Set Piston
The upper and the lower rings are mounted perfectly, but the middle ring (OIL) is big and wouldn't go in the piston. :(
The older ring it thinner than the one I got on 12033-7S003 in the width
Now, I just want to fix this issue ASAP.
Thanks again guys.. and hope ot find a solution soon.. :scheibe-big:
I'm not sure I understand your problem. The oil ring is the bottom ring, not the middle ring. It sounds like you are trying to install the rings in the wrong positions.
well .. maybe I got that wrong from the mechanic... but let's check the parts first... would those numbers goes together..
It's Friday over here.. I will stop by on Saturday to take pictures to illustrate the problem..
Thanks for the reply ;)
