1 - 11 of 11 Posts
I've searched everywhere, and no one can answer a seemingly easy question. What intakes will fit the 05 Titan? I didn't think anything changed between 04 and 05, but no one can give a straight answer. I'd love to order the Volant intake for my truck, but I'm not sure that it will fit. Please Help,
Joe
I would think the intakes are the same on the 05's but I can't tell you that for a fact. Post a pic of your intake and I'll look at it, it should be the same.
Just installed one on my 05 today. Fit's great!!!
I am currently leaning towards the Volant but I have a question... Is the Ram Tube required if not does it make a difference?
Go fast tester
No it's not required and I hear there is some worry about picking up debris with it. I think I have heard JetTech or someone mention this. But it's def. not required.
thanks, that will save me a $100!
Just make sure to cap off the lower inlet of the airbox where the ram air tube would go. I'm not sure if Volant is sending out caps these days or not, but if they're not a spray paint can top works perfect to block it off. If you don't block it off you'll be sucking hot air right off the exhaust manifolds.
Do you have to add something to form a gasket around the paint cap and the hole?
I just put a bead of high temp silicone around the cap and sealed it in. It fit tight in the opening to begin with but I didn't want to take any chances of it getting loose as things heat up and cool down.
JT, you're full of all kinds of good information...Thanks for the tip. :D
1 - 11 of 11 Posts
