Hi Greg and welcome to the forum. Posts are listed chronologically within each thread. If you want to reply to a specific post, use the "QUOTE" button at the top of the post you want to reply to (such as I have done to your post). You will be taken to a message body box to type your response and the persons post will appear between some codes in brackets.Greg said:Hi everyone:
I posted a question and a few people replied. I tried to reply to there post and it looks like it didnt show up under there post but at the bottom.
What step am I missing?
Greg
As you can see m4ck beat me to replying to your post. You can also edit long quoted posts down to a few lines such as I have done with the post by m4ck (although his post was not long, just showing a helpful example). Just do not delete the bracketed codes. This helps also if you want to respond only to a specific part of a long post.m4ck said:Top right hand corner...
Caltitan said:You can also edit long quoted posts down to a few lines such as I have done with the post by m4ck (although his post was not long, just showing a helpful example). This helps also if you want to respond only to a specific part of a long post.m4ck said:Top right hand corner...
for the infom4ck said:Top right hand corner of the post you want to reply to click QUOTE.
by the way welcome aboard.
