1 - 9 of 9 Posts
Most jurisdictions require some form of muffler, some require "industry standard" others require as little as a resonator. Read through your local regulations.
Personally I've done the obnoxiously loud truck thing and I doubt anyone will be happy with a straight piped Titan for very long.
Discussion Starter #3
Thanks I just wanted to move it around and not sure I could do it all in a weekend
Didn't want to hurt the truck if I had to drive it
As long as whats left on the truck is supported by the hangers it shouldn't cause a problem. For example I wouldn't drive around (much) with just headers and the b-pipes as the b-pipes are not supported. With the muffler and tailpipe removed and the intermediate pipe(s) supported by their hanger the truck shouldn't have a problem, your neighbors might though.
Discussion Starter #5
That's the problem I've been having the first owner must have tried a different muff and then wielded the xlerator cat back right back on with out bringing spec length back to original so all hangers from muffler back keep snapping and now I just took cross pipes off and turned it down which has melted my park brake cable so I want to start over with cherry bombs hotrod series but can only afford 1 at a pay period and need the muffler off for a couple weeks and and screw my neighbors there not friends of mine
G
Discussion Starter #7
I never got around to it but still might never the less is it bad for the truck or can it hurt anything
Also back pressure may be compromised if you uninstall the muffler. How about just replacing the system with a decent exhaust like flowmaster or magnaflow. It would surely sound and perform better.
1 - 9 of 9 Posts
