I installed OEM bug deflector yesterday. Here are my opinion on it:
Scale from 1 to 10
Fit: 9
Look: 8 because of the screws. You can see the screws from outside. It will be a 10 if they some how design to hide the screws.
Installation: 8 Easy to install but the instruction a bit confussion.
Ease of use: 6 The Clear rubber pieces under the bug reflector make it hard to clean/dry the hood space between the bug reflector and the hood. It is hard to to take out and clean the hood and install it back in if you have to.
Over all, it has a good look costmetic design but bad engineer design.
Scale from 1 to 10
Fit: 9
