Ok ive about had it. Front grinding
1 reading
6.7K views 3 replies 2 participants last post by  jrw396
#1 ·
Ok I know someone here has dealt with this stupid problem.
So its a loud grinding noise from the front right side. It sounds and feels like the front passenger wheel is locked up. Only does is it at low speeds (5 -20mph).
I have replaced:
Both front rotors
Front pads
Both front wheel bearings. Passenger side twice.
2007 SE 2WD
110K miles
Any help would be greatly appreciated. Thanks
#2 ·
Having the same problem only I replaced the front calipers and still having the problem.
#3 ·
It was the carrier bearing. It sounds like its coming from the front but it sits right under the console on the underside. The bearing holds the center of the 2 piece driveshaft. Firestone fixed it for me.
#4 ·
Thanks for the heads up. I'll have it checked out.
update: Carrier bearing is ok. Have to find the grinding sound coming from front drivers side brake under hard braking. Still open for ideas.
