My 2004 CC Titan LE W/navi only has ac or heat coming from the defrost and or floor vents. I can turn the knob and hear the dampers moving. Air flow stops coming out the defrost then nothing comes out of the dash vents ( the ones than blow air directly at you) then it automatically reverts back to defrost. No matter what mode is the knob is in (max air, dash, floor, or defrost). I dont hear creaking or popping from actuator from stripped gears like most people are posting about in my research. My has been broken for a few months but magical began working the other day, but the next morning I had to use defrost. I switched from vents to defrost but now it won't go back to vents once again.
Which actuator is bad and what is the part#?
Here's the question what actuator, I've replaced the whole heater core, which isn't a separate piece, it's the whole box, 3 feet long in the dash. 3 times already and at $2,000.00 each time I'm over it. I kept the last one and, Now just a click and went it out again. I can't keep having my dash ripped apart to do this, it's old and getting brittle. All I get now is defrost on the windshield, side window defrost and floor vents.
