Hey everyone.
I hope I've posted this in the correct forum section. If not, please forgive me. I couldn't find the troubleshooting/problems section.
Anyways, I own a 04 Nissan Titan, of which the headlight (driver side) has gotten foggy. It's certainly not as transparent as the passenger side light. At first I wasn't sure why one was foggy and the other wasn't, but then I took a closer look at the foggy light and noticed a small crack on the outside casing. I believe this crack has allowed moisture to enter the light. I've heard of people restoring their headlights with special DIY kits, but I've decided to take the route of simply replacing the light with an aftermarket light from an online store. I found two sites that I particularly liked, but I'm unsure of whether or not they are legitimate businesses. Furthermore, I don't want to fall prey to a scam. Has anyone purchased from either of these sites and can verify that they are a legitimate business? The following parts match the OEM number of the one I need. Thanks in advance.
http://www.autofitexpert.com/product.php?id_product=65778
or
http://www.autolightcenter.com/nissan/titan/all.html?year=2005#MTQxMjk
never heard of either site. wouldn't touch either personally. if you are looking to replace your headlights, i'd say go with ebay with some aftermarket or stock ones. if you go with the aftermarket, it wouldn't be a bad idea to beef up the seals on the lights just in case. but depending on how bad your lights are now, they may be fixable.
My drivers side was fogged for a while, I took a bulb out and stuck my air compressor hose in the light for about 20 minutes to dry it up, then I put some silicone all around the seal, its been dry since I did this over a year ago.
