2013 Nissan Titan SV 4x4
Hello all- I have a 2013 Nissan Titan SV 4x4 and I’m having power window issues. The only has 45,000 on her. While using the drivers side window switch- drivers window rolls up and down just fine. Passenger rolls down but won’t roll back up. Passenger rear goes down an inch and stops but also rolls back up. The drivers rear is fine.
Now, going to the other doors and using the switches on each door: all but the passenger rear is fine. The passenger rear still only goes down an inch, even using that switch. Thoughts?
Discussion Starter #3
Hi.. have you gotten this issues resolved? If not you probably have a bad window regulator.
I have not as of yet. I’m thinking you are correct and will probably replace it soon. Thank you so much!
