2008 Titan SE driver window works sometimes. Then sometimes it doesn't. let's say, for instance, I roll the window down halfway (only sometimes) then it will not roll back up. I can grab the window by my hand and try to pull it up. There will be about 1/4 inch of play. I can either pull it up until it stops or push it down until it stops. Then the switch will work. But the problem is getting progressively worse. This morning it took me about 5 minutes of messing with it until I got it to roll up. But then again I might go out there right now and it will work perfectly.
I am not a novice mechanic but I am not a master mechanic either. Someone, please help me diagnose this before I take it apart. Or if anyone has had this problem, what did you do to fix this bug?
