I've got an 04 Titan and it seems to be building up pressure in the coolant reservoir . And doesn't seem to be flowing back out of it once it's in there . It's filling completely to the top and staying under pressure .
One of the main goals of engine manufacturers is to increase the COP, which ideally should be up to 100%. But at the moment, internal combustion engines used in cars are far from ideal. During their operation, a considerable amount of energy is spent on friction and heating. Because of the resulting heat, a cooling system has to be installed in the car. At the moment, the most common is the liquid cooling system of the car engine. It is filled with a coolant (toluene or antifreeze), which circulates through the system under pressure, cooling the corresponding units. By the way, you can look for yourself at What Type of Antifreeze and Coolant for Cars. How Much
