ok guys, i got around to doing the "axle vent mod"...YES, i found it on my axle HRTKD.....as i said, i thought it was part of the axle tube - a cast piece of metal....NO, IT WAS THE FACTORY VENT ALL RUSTED/CAKED UP.
while under truck inspecting things, i found this little beauty....
my front shaft-diff - missing a bolt and the other one in the pic was just about to fall off.....NICE, that would have been a fine how do you do repair bill....ANYONE know if any G8 bolt will do OR do i need a factory specific one? can anyone say loctite?
Holy crap! Missing a bolt on the drive shaft??? Grade 8 should do fine. I would get something in there ASAP, at least to hold it until you can get to the dealer and purchase an OEM bolt (but I think a grade 8 is fine). Be sure to match the existing bolts - they should be metric.
well it is not the front of the driveshaft BUT the front short shaft out of the front diff to transfer case......for 4x....
spose i am making a trip to the dealer for the OEM metric kind....
That is the driveshaft.
Good thing you caught this, it could have caused a big and expensive problem.
YUP...
thanks to the NISSAN spec page i had found for the needed parts....oh wait, they don't exist anymore....
they got superceded...
FYI: to those who may need new front drive shaft bolts, here are the NEW numbers.
37120-4p00a - bolt
37171-7s00a - nut
the parts guy could not give a reason as to why the change, said perhaps this is the reason - they fall out - so i bought all 4 and will install w/ loctite...
the guy gave me 'wholesaler' price or otherwise a nut/bolt would have cost me $5.47, so i was out the door at $17 instead for all 4.
p.s. also grabbed a cabin air filter from autozone today as well....tired of smelling/tasting dust and smells....not sure why the XE's never came w/ it...stupid
well guys, i got the driveshaft bolts replaced tonight WITH red loctite...
I RECOMMEND YOU ALL GO CHECK YOURS....cuz the other 2 were barely finger tight...with the 1 just being there and the other 1 gone...
shocking actually.... i cranked them down good too....
