1 - 2 of 2 Posts
I know the vehicle is rated to handle the load of my new travel trailer but any tips. It's the largest load I've ever pulled with a 1/2 ton. Usually less than 4000lbs for me. I'll be traveling through mountains with decent grades over the next few years so if you have anything that helps. Concerned if transmission could overheat or is that ever a concern?
Should have no problem ive towed 10k pluse now for not more than 100 miles but do several times throught out the year sorry not much more than be confadent your Titan will be up to it saying that I have rear air bags change rear lube every yr with Amsoil sever gear and setting up trailer breaks and have used power stop pads n rooters on the truck with good luck
1 - 2 of 2 Posts
