1 - 2 of 2 Posts
I was looking at pics of the duct for the Volant box ram air tube and was wondering if anyone had pics of how it is laid out when installed. Specifically I'm looking to see where it is routed in the engine bay and also where it goes in relation to the frame rail there on the driver's side. Does it go to the engine side of the frame rail?
The reason I ask is that the electric fans take up less room in the engine bay and I see no reason why I couldn't run a 3" dryer hose the entire way to the front. I could probably run a 3" PVC setup too...
Thanks in advance.
Banned
Dryer Hose??
Hi,
Just a thought here about the possible use of dryer hose. Don't do it as it would produce such turbulence and drag as a result of the corregations of the hose that any possible benefits of "Ram Air" would be lost. Now, using smooth PVC might work well. If you were to custom bend it by using heat and not using any joint couplers, you would achieve maximum gain.
1 - 2 of 2 Posts
