My wife heard a weird noise in the front end, the way she described it I thought it sounded like a wheel bearing. I took it for a spin, not a bearing, but I heard what sound like something metal vibrating. Started to investigate under the truck and this plate sounded like it was rattling
Wheel Tire Vehicle Automotive tire Motor vehicle
Grabbed my 12mm socket, tested all the bolts and found the rear passenger side bolt (closest bolt on the left) would turn, so I gave it some tightening, and plate still sounded loose. So I used my camera to look around and saw this:
Automotive tire Hood Rim Wood Automotive exterior
Got the bolt out. 14mm flanged bolt. Can't see any place that is missing a bolt. So, any thoughts?
Automotive tire Asphalt Road surface Gas Tints and shades
I will see if I can double check the brake calipers. Odd if it is though to find that bolt in the middle of the truck under the differential and oil pan plate.
