1 - 2 of 2 Posts
I had a Myron Davis flip down installed and per the M&D instructions the install rep disabled the rear audio controls. How can I go back and re-activate the rear audio controls on the head unit. Is there a connector that was unplugged? I know there may be a conflict with the factor IR, however, I'd at least lick to check and see.
CK
Take out the glove box, under that and behind the passenger kick plate you will find all the connections for the audio controls. I am not sure whichj ones to tell you to check but all the connections are under there. And behind the fuse box on passenger side dash.
1 - 2 of 2 Posts
