New owner here from Arizona. I purchased a new grill from Grill4u. The instructions say to remove the grill but I can't figure out how to do it without doing any damage. So far all I've managed to do is break the four little square plastic nuts at the top of the grill. I find the instructions are not very clear.
Go fast tester
I'm sure someone here will help ya Joe. Welcome to the club. Most of the grills I have seen go over the original one. You may need to remove the Nissan emblem but I don't know what type you have. Let everyone know the brand and maybe someone with the same thing can chime in on it.
If you use a screwdriver to twist the square heads 45 degrees you can pull the grill foward to release it while you have the head turned. Look at this:
