I am trying to remove my TITAN's 3rd Brake Light Lens to replace a bulb. There are no screws to remove it. It must come off...but how? Thanks! :?
Banned
Have you pulled the unit out of the truck yet? If not, there are two plastic caps in the headliner just above the opening portion of the rear window. Pop those out and using an 8mm deep socket and extension on your ratchet you can reach the nuts holding the light unit into the truck roof.
From there you are on your own as I've not done more than loosen the light to allow access of the antenna wire for my XM radio.
Hope this helps.
  • Like
Reactions: ecnar
Hope this helps.
2017 nissan titan xd has no plugs in headliner
