I knew I remembered seeing this. It was on TT
http://www.titantalk.com/forums/showthread.php?t=14936&highlight=column+shifter+recall
Report Date : September 1, 2004 at 02:46 PM
TYPE : VEHICLE
YEAR : 2004
MAKE : NISSAN
MODEL : TITAN
Results : 2 | All records displayed
Make : NISSAN Model : TITAN Year : 2004
NHTSA CAMPAIGN ID Number : 04V408000 Recall Date : AUG 09, 2004
Component: POWER TRAIN:MANUAL TRANSMISSION:COLUMN SHIFT ASSEMBLY
Potential Number Of Units Affected : 5664
Summary:
ON CERTAIN PICKUP TRUCKS EQUIPPED WITH A COLUMN SHIFTER, THE SHIFT LEVER ASSEMBLY FOR THE COLUMN SHIFTER MAY HAVE BEEN DAMAGED DURING ASSEMBLY.
Consequence:
DURING ITS USE THIS COULD EVENTUALLY RESULT IN FAILURE OF THE PORTION OF THE ASSEMBLY THAT HOLDS THE LEVER IN THE PARK POSITION. THIS COULD RESULT IN A CRASH.
Remedy:
DEALERS WILL INSPECT AND REPLACE THE SHIFTER. THE RECALL IS EXPECTED TO BEGIN SEPTEMBER 27, 2004 OWNERS SHOULD CONTACT NISSAN AT 1-800-647-7261.
Notes:
CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION’S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
Check to Request Research. Submit below.
NHTSA CAMPAIGN ID Number : 04V345000 Recall Date : JUL 01, 2004
Component: SEAT BELTS:FRONT:ANCHORAGE
Potential Number Of Units Affected : 59947
Summary:
CERTAIN PICKUP TRUCKS FAIL TO COMPLY WITH THE REQUIREMENTS OF FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 201, "OCCUPANT PROTECTION IN INTERIOR IMPACT." AN AREA ON THE REAR PILLAR WHERE THE REAR SEAT BELT UPPER ANCHOR IS ATTACHED MAY NOT BE SUFFICIENTLY ENERGY ABSORBENT.
Consequence:
THIS COULD RESULT IN AN INCREASED RISK OF INJURY IF THE AREA IS STRUCK IN A CRASH.
Remedy:
DEALERS WILL REPLACE THE OUTBOARD REAR SEAT BELT ASSEMBLIES WITH NEW ONES. THE RECALL IS EXPECTED TO BEGIN SEPTEMBER 27, 2004. OWNERS SHOULD CONTACT NISSAN AT 1-800-647-7261.
Notes:
This info can be found at NHTSA website:
http://www-odi.nhtsa.dot.gov/cars/p...lls/results.cfm
