1 - 7 of 7 Posts
INSTALLING A AVIC-N1,DOES ANYONE KNOW WHERE I CAN FIND THE REVERSE TAIL LAMP LEAD IN THE THE CAB?IF SO WHERE?
Without looking myself....I would suggest you try the main harness that runs along the door sill. I just looked at a DEI tech sheet and it said green/wht in the rearview mirror. I am not sure why it would be there, but they are usually very accurate.
I don't know of a source in the cab but, I do know that the backup light relay is located in the box just behind the battery. The lid snaps off and inside are all the relays. I used that as a source to energize another relay which switches power to some 55W aux backup lights.
G
There are wiring harnesses that run down each side, under the door sills. The wires to the backup lights are green/white.
ok i will check that out tomorrow,only reason i was checking also, was i pulled out the taillamps and there was a red/blue connected to the back up light?
G
I think the red/blue wire is the stop lamp, not the back up lamp.
1 - 7 of 7 Posts
