I have been looking for a cold air intake and have narrowed down to the S&B. I have a 2010 Titan FF,will the S&B intake work for me? I have only seen one part number for the 5.6L, #75-6012, yet the cut off year is 2007.
It will work fine for you. The 2010 OEM intake is the same as all the earlier years, so fitment should be ok.
you will be fine
I have the S&B intake on my 08 titan. The first picture is when I first installed it.
The second picture is with the Ram air mod, and I painted the clear cover black, also for shizz and giggles I had some DEI heat wrap tape that doesn't do a thing lol wrapped around the intake tubing, its more for bling I guess...
I'm eventually going to order the Relentless 4in intake setup.
Enjoy
Pic 1
Pic 2
i want to do this
Enjoy
Pic 1
Pic 2
can you please tell me where you got the transition peice from the air box to the hose? that's the tidiest set up i've seen since i started researching this mod
Here are some pictures of how I installed my Ram air.
The parts used I picked up at Lowes or Home Depot.
1x 12inch piece of 3in or 4in diameter Corrugated polyethylene plastic tubing (non-porous) price= less than $5
1x 3in or 4in Rubber coupling for PVC or Plastic pipes. $5
Time to dremel/cut/holesaw, however you choose to cut away plastic on the intake airbox and the section between the rear of the grill and front of the windshield washer container.... 1-Hour or so.
I cut my S&B intake air box with a serrated steak knife lol, thats all I had at the time, it worked great though, the plastic is really thin and flexible. I used a dremel on the hard plastic that you run the tubing through to the grill.
That is the install of my S&B intake with Ram air MOD.
The Picture below is of my new RELENTLESS RPM 4in Cold Air Intake and I'm comparing the S&B intake tubing diameters.
Hope you all enjoyed.
Just installed a S&B Intake on my 2009 Titan (thanks richworxs) and man is it BAD A$$. Need to do a little bit of modding to it, i.e. pipe insulation around the air opening on the box to seal it up with the port on the fender and put a little bit of rubber on the bottom for vibration betweek 3700-4200ish RPM but it sounds awesome otherwise and can definitely feel the power improvement. If you are debating this intake, don't, it's awesome.
