Site Sponsor
We are currently running a sale on the 04+ Titan 2 inch spacer lift!
http://nissteclifts.com/index.php?p...tegory_id=174&option=com_virtuemart&Itemid=72
2" Front Lift Spacer Kit with 1" Rear Blocks. HD 1.5" Rear Add-A-Leafs also available
Our front spacers are CNC Machined From 6061 T-6 Aluminum. This in the coil style spacer pre-loads your factory coil to give you lift and doesnt change the OE suspension geometry. The benefit in not changing your suspension goemetry is prolonged ball joint, CV axle, and TRE life.
*No UCA contact on the coil bucket and no need for extended bump stops*
Included in Kit:
(2) Front NissTec Lift Spacers
(2) 1" Rear Lift Blocks Made From Solid T-6 Aluminum W/ Pressed Steel Centering Pin.
* Please choose below for optional 1.5" Deaver Add-A-Leaf for Heavy Duty Applications. Rear AALs are ideal for those who tow a lot or carry a heavy load in the bed on a regular basis*
(4) Longer Rear Ubolts W/Hardware
On sale for $179.99
Be sure to check out all of our other Titan Products!
http://www.nissteclifts.com/index.php?Itemid=114&option=com_virtuemart
