Hi All,
My 4x4 seems to pull side to side when on the highway, feels almost like the 4wd is ingaged, so I switched it on and off several times, no change.
Now it does seem less noticable with the VDC off.
I have check the pressure in my tires and there 35psi.
Antone having this problem?
Does it only do it on certain parts of the road? The reason I ask is because different road surfaces will cause mine to act the same way, the tread of the tires is wanting to follow the grain in the highway. It's not very common for me to feel it but it does happen occasionally on the same sections of highway and on several back roads I travel.
I don't really see where the VDC would make any difference if your experiencing a pulling to each side. The only other thing that comes to mind is you alignment is out of spec. Too little castor will make the vehicle wander like your talking about, as long as your sure it isn't road surface.....Oh no, time for the dreaded trip to the dealer to have them check it out.....Good Luck!!
