Ok first you should probably go for a XE if you dont need all the packages. Main reason, if you are planning on putting in a new head unit you will have to buy a new radio console cover. The SE and LE have the RF radio package and you get that integrated radio dash thing. You would do better to get an XE because it has a regular dash and only requires a cheap dash kit. Like a Metra dash kit. I think its this one http://www.hififorless.com/showProduct.php?productid=68233
because its a double din unit in the XE. Plus you can get an XE for about 20 to 21k. Like I did. Oh here is a place you can get that dash if you go with an SE http://www.courtesyparts.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=68260-A60CC
Hope this is helpful. By the way welcome aboard.
