Day three with the Titan and I was out of 200,000 acres of open training area at Fort Stewart GA. The first real stream I crossed and both front wheel wells popped off of their mounting screws. See attached pictures. The screw heads are too small to hold the wells when water pushes up from the back side. After getting home a simple addition of large rubber washers from Ace took care of the problem. Did wear away the corners of the well on the drive home. Other than that the truck did very well in some very sticky situations. Only into low one time.
Jared
Jared
