I have a 07 cc stock with pro comp wheels 7098 series 18x9 with stock size 265/70-18 tires mounted on them. What tire size can I got up to before they start to rub or with out doing any pwm? Does not have a leveling kit(yet).
Thanks
no lvl kit with your wheels you should be able to run a 33x12.50x18 i have been looking at the 285/65/18 or a 305/60/18 for my truck with a 1.5" spacer for the front, both those tires are 32" tall so it will be closer to OEM for your speedometer to be close to the same.
Site Sponsor
Do you know what offset your wheels are?
If you stick within about 1" of your OE tires overall diameter and you will be fine. 275/70R18 would work great. 305/65r18 may also work but may rub depending on your wheels offset. Give us a call if you would like a recommendation.
If your rims are similar in offset to the stock wheels then you should be able to run 33" x 12.50" r18 tires with no rubbing on a stock height Titan. I get ZERO rubbing with my 33x12.50r17 Mickey Thompson MTZ Tires on stock offroad rims. I did not have to do any cutting or modifications, and there is still plenty of clearance even if I hit a big bump with the wheel at full cut. If your rims have a negative offset, you may have to do the pinch weld mod to fit anything bigger than 285/65/18 without rubbing.
New Tires
Had a 2" leveling kit put in. Just had the BFG AT installed went with 275 70 18 it's close might be an 1/8" maybe smaller gap when the wheel is turned all the way to one side. I don't see where you would be able to go any larger with out cutting the mud flap or bigger lift. looks frickin awesome....
