OK
Found a Titan finally that I am looking at picking up. Havent test drove it yet, but everything seems on the up and up. The seller the only odd thing is there is a popping noise from the torque convertor area. He had a mechanic friend of his check it out and he was told that its like a $36 part that needs to be replaced and it will take care of it. Has anyone ran into an issue like this at all?
Its a 2007 SE 4x4.
If its something that is major, I could change it out. I just dont want to buy something I think is a good deal then be suckered out here in a couple months to find its like a $5000 fix. I have changed out TC's before and do not know of any bracket, granted it was on a Toyota Supra but in general cars are cars
Thanks for any help.
i cant think of anything in the bell housing area that would make a "pop" sound. maybe a chatter or clank sound because the torque converter is loose or/and not torqued correctly. sounds have a funny way of traveling places. you will need to give some more characteristics. what are you doing when it happens? can u feel it? is it intermittent or predictable? etc...
there is a lot of people on here that have pop sounds that come from the front U joint (TSB btw), front/rear diff, ball joints, and shocks/struts
thanks for the reply
the seller ended up selling it out from under me when he committed to selling it to me
oh well the search still goes on
you got lucky, popping sound ain't good,when I heard that it was a rebuilt rearend.
