I had the recall done on the towing harness a couple of years ago and read on hear that when they do this they put a fuse in-line some where around the steering column under the dash. I looked for this fuse and couldn't find it anyone have any ideas? When I hook up a trailer I don't have park lights on one side but the same trailer hooked up to a co worker's truck all lights on trailer work. Thanks for any replies.
The fuses are in the added harness, next to the BCM. The BCM is on the firewall, to the right of the steering column.
Discussion Starter #4
Are the fuses in-line or are they in some sort of housing? Will I have to take the panel off under the steering column or can I see the fuses by looking up from the pedal area? Should I be looking right behind the data connector and just before the bcm?
