Hello everybody, You guys have helped me before so I decided to join. So here's my problem. My left and running lights wont work on my trailer. I've checked all the fuses, relay's, the truck came with the tow package and the trailer lights work when my buddy plugs into them. Help please. Thanks and hope I can help somebody also.
Probably the pins for the trailer harness don't match the connections on the truck. Trailer harnesses aren't universal although they appear to be. Take it to an RV dealer. I had a similar problem, but the trailer brakes were locked on when I first hooked up to my T. A whole $69.00 later the RV dealer (Camp Out in Bloomsbury, NJ) not only had the brakes working properly, but fixed other connections and even replaced some bulbs on the trailer.
If you had the trailer wiring modification done by the dealer (this was done on 04-05s), there are fuses under the dash. They are in a wiring harness by the BCM, near the steering column.
