Ok, I ordered an Autometer Trans Temp Gauge and have a few questions if anybody can help me. I've installed an aftermarket trans cooler, and need to know the best place to locate the sending unit sensor. Is it better to monitor the hottest temp (from trans), coolest temp (output of trans cooler), or somewhere in between? And are the trans lines 3/8"?
I have the XE Crew Cab and need a good source for the 12V ignition to power the gauge only when the truck is on, and also 12V for the backlight. Is there an unused harness on the XE that is available, or should I go to the fuse box? I plan on punching out a hole where I think the 4x4 switch would be located. The gauge is slightly over 2" and should fit perfectly there. Thanks.
