If you use Osiris to reflash the ECU with a new performance map from UpRev, will you need to reflash the ECU every time the battery is unhooked? The ECU resets itself after unhooking the battery for a few minutes, so what if you have it unhooked for hours while doing some work on the truck? Will you need to reflash with Osiris afterward?
Thanks!!
No...............
