The other day I used my wiper washer fliud and worked fine. Today I went to use because the pollen here in Orlando is totally out of control and nothing! Checked all the fuses by the glove box everything was good. has anyone had the pump go out. Any suggetions would be great.
I assume you have checked the fluid level in the tank.
The fuse for the pump is #9, a 10 amp, in the fuse block.
Mine went a couple months ago. I got a universal pump from Autozone and cut the pig tail off the old pump when i took it out and soldered it onto the universal pump wires so it was just plug-n-play during the reinstall. Otherwise, it's a tight fit in there to be messing with connecting wires, and I'm not getting an OEM pump when a universal was half as much. Works like a champ.
