I can't really search for this since I don't know what it is I'm asking about, I just know what it does and where it goes. So, what is it? :roll:
What is the grease/wax substance you put on the black thing that has the position stops when you open the doors? I noticed tonight that my drivers side front door popped a couple times while opening it. I found that the stuff on the black thing is causing that by sticking in a couple places. I would like to get some of this stuff so I can re-lube the black thingies.
PS> What are the black thingies called?
Havock,
I've looked through the service manual (Door sections) and can't find ANY information on them. I'll see if I can find any sort of a "Lube" section. You could always call the dealership.
Mine were dry when I took it to the dealer for an oil change I told them I had to slam the door to get it to shut, so they lubed it up for me I asked them what they used and all they said was a special lubricant :?:
Go fast tester
Special....probably 4 in 1!! I'm sure it was better then that....or all us okies...WD40 will fix anything!! :***:
What a jackazz for not answering your question!
I got a copy of the Service Manual and am guessing that this is what they use:
Multi-purpose grease — — — NLGI No. 2 (lithium soap base)
Can anyone confirm or deny this?
Here's the lube chart I used to make my guess:
Banned
Silicone Spray
If the "Black Thingies" in question are made of rubber, then use some silicone spray. They make it so it leaves a dry coating and doesn't rub off on everything.
I spray my door gaskets all the time with this sturff and the doors open in winter without problem.
Re: Silicone Spray
Kinda off topic here, but in regards to the door gaskets, the best stuff I have ever found is called "gummyphfliege" (something like that). It is only available thru a BMW dealer. It is the most amazing rubber conditioner I have ever seen or used. It will stop any gasket sqweak and will never freeze. It actually makes the gaskets seal better too. Anyway, just thought I'de mention it. I found out about it on an Audi forum when I had my A4. Gotta love these forums! :D
