SHIFT_chicks-rule!
I know what the bolt pattern is on our wheels, but what is the off set and the center bore for the 18X8 OEM wheels on a LE?
Hi Deb, I can't find it in the service manual. Have you looked in the owners manual? Sometimes offset information is located in them.
Offset on the 18" LE Wheels (6 Spoke) is 25mm or roughly 5" of backspace. As far as the centerbore I have heard mixed and I don't know the exact size but one person told me it was just a hair smaller than Chevys and one person told me it was just a hair larger than Chevys. I have also heard it is exactly the same as Toyota. I am curious too.
SHIFT_chicks-rule!
The owners manual has a warning (pg 8-37) always replace wheels w/same off-set.....can be found in Tech. and Consumer info. Not there, only the size(18x8.0)
SHIFT_chicks-rule!
Is that +25mm or -25mm? And if i found some wheels that are +14mm, how does that affect anything??? :? :? Brakes??? How far they stick out??? I know!! :idea: I need someone to crawl under the truck and show me what all this means because I just don't understand. :cry: I read all the tech stuff at The Tire Rack.....still nothing.
SHIFT_chicks-rule!
Here, check out this site. It's great for figuring out your wheel and tire size combinations.
http://350zx.com/tire-wheel.html
The OEM 18" wheels are 18x8 with a +25 offset. As far as the center bore you might want to check with discount tire or tire rack and see if they can tell you.
It is +25mm. If you got a wheel that was 8 inches wide but had a +14mm offset you should be just fine. They will stick out a tad more from the fenderwell but hardly noticeable.
