Hi everyone I have a 2006 titan and this morning it wouldnt start and I still cant get it started my bullydog is showing a code p2119 throttle actuator control throttle body range/performance I cant seem to find any information on this code any advice would be apreciated thanks
When you say it won't start does that mean it won't turn over or it turns over but won't fire? If the ECU relay in the IPDM has failed then the symptom is that the engine turns over but won't fire. Swapping the ECU and flog light relays is a quick test that will help you narrow down if it really is the ECU relay at fault.
