After much researching, I decided to go with the newest release from XM radio, the Skyfi 2. It has an FM modulater built into the cradle that it rides in, so all I have to do is tune to one of the designated fm stations, and I have my sat radio! There is no direct hardwire hookup to my stock radio at all. Here are some pics of how I installed it.
The micro intenna is centerd on roof where windshield meets it. The wire is tucked behind the weatherstrip of the windshield, then along the opening between the fender and hood, into the door jamb.
I then pulled the top plastic plug from the door jamb, and drilled a hole for the wire to get under the dash. After running the wire through the hole, I filled it with silicone, and replaced the cap.
Ran the wires under, and accross the dash. Pulled the radio cover off, drilled a hole under the rubber mat on the top part of the dash, and ran the wires up and out.
I am very pleased with how it turned out.
